charles-1 avatar image
charles-1 asked
Lynx BMS/Distributor - Can you mount it like this? Tight space to install
Hi, just curious if I could mount and wire my Lynx system like this:
Don't have a lot of room to work with!
Thanks!
Charles
installationlynx shunt
Running them vertically would be better.
You can lay them out as shown. A single arc as in the bottom would be better, the double arc as shown for the top is going to be more difficult.
Be careful of tight cable bend radius, and make sure you are using sufficiently large/rated cables for the interconnects. You don't want any tension on the lug, which seems very likely with this wiring configuration.
charles-1 avatar image charles-1 commented ·
Thanks! No problem with going with a single arc at the top.
goldrush avatar image
goldrush answered ·
Would be great if Victron would put out pole connectors to allow these configurations.
