Odd avatar image
Odd asked
Charging Battery problem ?
271746416-460037352366639-6768913643505068711-n.jpg271947569-669380964263315-6435417792740451563-n.jpg271860412-4936482136412215-6399367025765545645-n.jpgHello everyone. Wondering if the batteries are damaged. trying to charge with a victron multiplus ii 12v / 3000. Look at the pictures that are attached. The batteries showed 10.55 v and 99% when I started charging. Charges for about 40 minutes and the batteries show 13.7 volts and 100%. When charging is 100% should not charging current be made automatically? I stop charging after 2 hours and then it shows 13.7 v and 100%. and after 30 minutes it shows 12.28 v and 100%. multiplus is turned off after charging.
Has multiplus ii 12/3000 and bmv 712. 8 * 115 amp lead battery in paralell
battery charging
Charge until the MultiPlus is through all charging stages (bulk, absorption and float), this can take 10-12h.
What are the settings of the BMV? Maybe it is jumping to 100% to fast?
Odd avatar image
Odd answered ·
Will try to charge for a longer time. State of charge is at 100 % but voltage only 11.82v
Here is the pictures from the bmv. Need to change some settings ?
kevgermany avatar image
kevgermany answered ·
Battery capacity in BMV should be 920, not 1120. (8*115)
Charge efficiency probably needs to be 90 or 85.
Need to see the charger/battery settings for the multiplus.
Odd avatar image
Odd answered ·
Sorry type error. 8*155 *0,9 becose they are old. will try to change charge efficience to 85
Here is some more pictures.
Thanx alot for helping.
Thanks
You need to think of charger and monitor separately.
Charger works on voltage and time. It charges at max current until absorption voltage reached, then keeps voltage constant until time limit reached, then switches to float voltage. Battery voltage should drop slowly to the float voltage. In general lead batteries are about 80-85% charged by absorption voltage. If the absorption voltage is reached quickly from start of charging, and start voltage was low, it indicates faulty/worn out batteries. In this condition the batteries hold much less power than when new.
Monitor works on current through the batteries. But resets to 100% charge when charged voltage is reached and the current drops to tail current or less for the detection time. State of charge is calculated on current measured and the capacity you enter. If batteries old/worn out SOC calcs will never be correct as capacity does not match the real capacity
Charged voltage is set below absorption in your system. But not too critical as current should remain high during most of absorption.
Your charging settings look good. Judging by what you're seeing, it's as you guessed. New batteries needed. But just try checking the charge current through the full absorption cycle. You might be undercharging. But regularly undercoating by switching off the charger will shorten the battery life.
By the way, if you replace try and use fewer bigger batteries. Big strings of batteries aren't ideal
Odd avatar image
Odd answered ·
Have charged for 3 houers now. shudent multiplus show state of charge. Still charging at 100 %.
I was thinking that the charge speed was going down when battery get 100 %
Multiplus 1643540710104.pngbmv 712
Odd avatar image
Odd answered ·
No i have charged for 3 hours and 1 hour of this was absorption . Now everythings looks better.
Dont have this fast drop in voltage. Using aboth 30 w now and almost none drop.
So i will try to start charging for 12 hours when i am at the cabin.
Think i has bean charging to little. only charging for 1-2 hours when needed.
So hopefully this battery will work for a time now. Going to start looking for new batteries soon.Think i will go for litium.
Again thanx for helping
If you can, leave it on permanently. The charger will switch to float mode, then, if it's in you unit storage. This keeps the batteries at an optimal level and stops the deterioration from being undercharged.
