gone-sailing avatar image
gone-sailing asked
Humidity on VRM
HI, I am creating my own temperature and humidity sensor using an Arduino. I am sending reading from Arduino via MQTT. I am able to see the temperatures on VRM but I do not see the humidity value. According the the VRM update on 7th December the Humidity value should be displayed on the VRM dashboard underneath the temperature.
The MQTT topic I am using are:
For temperature: W/<portal id>/temperature/<device id>/Temperature
For humidity: W/<portal id>/temperature/<device id>/Humidity
I can also see the values on the local Venus MQTT (using MQTT Explorer) at
N/<portal id>/temperature/<device id>/Temperature and N/<portal id>/temperature/<device id>/Humidity
Am I doing something wrong?
Regards
Martin
VRMTemperature SensorMQTTtemperature
What's firmware version of your Venus OS?
Hi @gone-sailing,
thanks. That explains why you're not seeing humidity. Meanwhile we're at 2.80~41-large-25 and humidity became available with the 2.80~33-large-24 I think. I suggest you follow the "tracker" for new announcements on the large image here: https://github.com/victronenergy/venus/issues/378
You'll find the download link to the dropbox link somewhere in that thread.
9 comments
Igor Sarychkin avatar image Igor Sarychkin commented ·
Hi, @Stefanie I have the 2.80~33-large-24 installed. SignalK is connected to VenusOS locally via its plugin with the dbus interface and all Victron data shows fine on VRM. I also have a wireless SensESP temperature sensor that sends deltas to SignalK server with a configurable SignalK path (e.g. environment.inside.temperature) - this also shows fine in SignalK's Data Browser. Is there a way to convince that temperature data to display on VRM? I tried various configuration via the Victron's MQTT but with no luck. Any pointers would be much appreciated. Cheers.
Stefanie (Victron Energy Staff) avatar image Stefanie (Victron Energy Staff) ♦♦ Igor Sarychkin commented ·
Hi Igor,
I think this is not possible out of the box. The only temperature sensors natively supported by Venus OS are those connected to the generic temperature input of a GX device and recently the RuuviTags via Bluetooth and I heard that also some Shelly will get support in the future. Everything else requires extra coding effort to make them available on the D-Bus.
D-Bus (internal data bus) is the keyword here. To show data on VRM, it first needs to be made available on D-Bus. I suggest reading this to get an idea how much effort it is to make a driver for your sensor: https://github.com/victronenergy/venus/wiki/howto-add-a-driver-to-Venus
Not sure if it's worth the effort or maybe easier to get one or more of these excellent and cheap Ruuvis.
Igor Sarychkin avatar image Igor Sarychkin Stefanie (Victron Energy Staff) ♦♦ commented ·
Thanks, Stephanie. My devious plan was to try and manipulate the d-bus interface via the Victron's MQTT broker and "W" (write) topic, i.e. the same format used by @gone-sailing - W/<portal id>/temperature/<device id>/Temperature . Ruuvis sensors might be easier but it's a bit problematic for me at the moment with the boat being 2000 nm away ;)
gone-sailing avatar image gone-sailing Igor Sarychkin commented ·
You need to run a device service on your GX device that sets up the dbus with a device instance. If you have a little python skills it's not too hard. Then you can publish messages to the appropriate MQTT queue from any other device.
Igor Sarychkin avatar image Igor Sarychkin gone-sailing commented ·
Got it. Found more info re dbus and the RPi built in temp sensor. Thanks very much, @gone-sailing
I wish I could help you here, but my programming skills are rather abysmal. I need to see a working example to understand how it works. Maybe @gone-sailing can share more information on that and provide us with step-by-step guide.
gone-sailing avatar image gone-sailing Stefanie (Victron Energy Staff) ♦♦ commented ·
What I have now is just a POC, it still needs more work. I will happily share it all once it is completed.
Stefanie (Victron Energy Staff) avatar image Stefanie (Victron Energy Staff) ♦♦ gone-sailing commented ·
That would be cool. Thanks.
Cheers, Stefanie. Working examples is all we need :)
gone-sailing answered ·
I'm running the Venus V2.80-21 Large on a Raspberry pi for dev/test purposes. I don't think there is a later Large version.
thanks, upgrading to latest large image has fixed it. All working now.
