hey,
how can I control the relays via Venus OS?
hey,
If you are asking where this overview page comes from, it's part of my GuiMods package:
https://github.com/kwindrem/GuiMods
Besides manual control, Relay 1 can be set to be controlled by conditions within Venus such as generator start/stop, tank pump or alarms. As of Venus v2.80~36 the relays can also be controlled by temperature sensors. All these setups are from the standard Venus menus, starting with the Relay menu to select the function for each relay. Then, additional setup may be needed in the menu for that functionality (e.g., the Tank Pump menu allows selection of which tank and the start/stop levels, or the Temperature Sensor menu inside the Relay menu).
yes I use a pi3 - and maybe I want to use some relays not all 6 relays but maybe two.
like this head?:
I know some relay hats use active low which creates issues with Venus OS since there is no way to change the polarity.
Search around on the forum for more help or relays for Venus. Sorry, it's just an area I've never looked into.
I use this one with my Pi 3+: https://www.amazon.com/gp/product/B072XGF4Z3 and it works well. The only thing I had to do is modifying the "etc/venus/gpio_list"
#### modified for use by the RpiGpio package on Raspberry PI platforms ONLY # This is a list of gpio pins, set by the script /etc/rcS.d/S90gpio_pins.sh # They are documented at: https://github.com/victronenergy/venus/wiki/bbb-gpio # Format: <pin_number> <direction: in/out> <name> # # The <name> part is used to create an symlink in /dev/gpio. # relays are active HIGH # Relay 1 Pin 40 / GPIO 21 CHANGES FOR RELAY HAT: -> GPIO 4 4 out relay_1 # Relay 2 Pin 11 / GPIO 17 CHANGES FOR RELAY HAT: -> GPIO 22 22 out relay_2 # Relay 3 Pin 13 / GPIO 27 CHANGES FOR RELAY HAT: -> GPIO 6 6 out relay_3 # Relay 4 Pin 15 / GPIO 22 CHANGES FOR RELAY HAT: -> GPIO 26 26 out relay_4 # Relay 5 Pin 16 / GPIO 23 23 out relay_5 # Relay 6 Pin 18 / GPIO 24 24 out relay_6 # these have pull UPs # Digital input 1 Pin 29 / GPIO 05 5 in digital_input_1 # Digital input 2 Pin 31 / GPIO 06 CHANGES FOR RELAY HAT: -> GPIO 17 17 in digital_input_2 # in stock code these have pull DOWNs #### modified to pull UPs by the GPIO overlay that is installed as part of this package # Digital input 3 Pin 33 / GPIO 13 13 in digital_input_3 # Digital input 4 Pin 35 / GPIO 19 19 in digital_input_4 # Digital input 5 Pin 37 / GPIO 26 CHANGES FOR RELAY HAT: -> GPIO 27 27 in digital_input_5 #### Gracefull shutdown input #### Note this input is NOT added to the available I/O used by Venus OS !!!! # Pin 36 / GPIO 16 16 in digital_input_6
that works. thanks for that.
can it be that from time to time it adjust again or when something is updated?
can you save the setting permanently?
A venus firmware update will overwrite the changes to the gpio_list file. Consider using my RpiGpioSetup package along with SetupHelper to keep the changes. RpiGpioSetup now supports a custom gpio_list file.
After the update to 2.80 the relay overview area is empty.
Under settings I can't find the item relay anymore
what happened? :(
Is RpiGpioSetup shown as installed in PackageManager?
Are you running the large version of Venus OS. If so, there's an update to SetupHelper that fixes an install bug for all packages.
Otherwise, hard to say without logs.
Hi Kevin,
can you please give me a little information how the gpio_list file in the RPIGGpioSetup should look like or how it can be setup? There is a section in "/data/setupOptions/RpiGpioSetup" called "optionSet". I'm a little bit confused how to handle it to keep the settings.
Thanks!
The RpiGpioSetup package contains a default gpio_list file. That file should work when using the GPIOs on the 40-pin header, but if you are using a relay HAT, etc, they may not be correct.
You can copy that gpio_list file to /data/setupOptions/RpiGpioSetup then edit it to change the assignments. The package will look for /data/setupOptions/RpiGpioSetup/gpio_list first before installing the default one.
The assignments you make in this file will depend on the harware you are trying to use for Venus digital inputs or relay outputs.
The custom gpio_list file is independent of the optionsSet flag file.
"optionsSet" is a file that tells the setup script that the options have been set by the user. Once they have been set, they persist in the setupOptions directory and survive a Venus firmware update. If the options have been set, the setup script will be run on the first boot following a Venus firmware update. If the package requires options to run the setup script without user interaction, as happens during during a reboot following a Venus firmware update, the setup script will not reinstall the packages. if the optionsSet flag file is not present. Most of my packages don't require any setup options, so the setup script will skip the optionsSet check. At this point I think only package that requires command line options is VeCanSetup.
29 People are following this question.
