petajoule avatar image
petajoule asked
making use of programmable relays in ESS
Given medium size(?) installation:
3 x Quattro 5kVA in 3-phase configuration
2 x MPPT 250/85 - evidently DC coupled
1 x Fronius Symo - AC coupled
1 x Venus GX
on last count, the docs mention a total of 13 (2 x 1 of the MPPTs, 2 in the Venus GX and 9 in the Quattros) programmable relays, where the 9 (3 x 3) of the Quattros probably behave like just 3 (yes?) in sync.
I'm missing the relay functions in Venus and Quattros under ESS operation. There is docs for the MPPT relay functionality.
Ideally, I would like the Venus GX relays to indicate various "excess energy" states. I can get a "battery full", but on top of that I would need
* "MPPTs are (about to) being throttled"
* "Fronius is (about to) being throttled"
So this could trigger some consumers to shave off some of the excess energy. HowTo?
ESSRelay
usernamepasswordbs avatar image usernamepasswordbs commented ·
#Petajoule Did you get anywhere with "MPPTs are (about to) being throttled"?
Is it in the code somewhere?
Much appreciated if you can tell me.
mihair avatar image
mihair answered ·
As far as I know, you can use either dbus or node-red
Personally I prefer to define a script using dbus and then to run it with crontab.
As an example of controlling relays:
#dbus -y com.victronenergy.system /Relay/1/State SetValue 1
Above command will set Relay1 ON (close contacts)
you can check if it is closed or not by issuing :
#dbus -y com.victronenergy.system /Relay/1/State GetValue
Please use dbus-spy to get all the paths for you script
As another example, here is a small script which I use to interrogate EM111 grid meter for TotalEnergy, L1 AC voltage and current:
#!/bin/bash
RE=`dbus -y com.victronenergy.grid.cgwacs_ttyUSB2_di32_mb1 /Ac/Energy/Reverse GetValue | awk '{printf("%d\n",$3 + 0.5);}'`
FE=`dbus -y com.victronenergy.grid.cgwacs_ttyUSB2_di32_mb1 /Ac/Energy/Forward GetValue | awk '{printf("%d\n",$3 + 0.5);}'`
TE=$(($FE+$RE))
echo Total Energy $TE kWh
ACC=`dbus -y com.victronenergy.grid.cgwacs_ttyUSB2_di32_mb1 /Ac/L1/Current GetValue | awk '{printf("%d\n",$3 + 0.5);}'`
echo Current $ACC A
VCC=`dbus -y com.victronenergy.grid.cgwacs_ttyUSB2_di32_mb1 /Ac/L1/Voltage GetValue | awk '{printf("%d\n",$3 + 0.5);}'`
echo Voltage $VCC V
petajoule avatar image petajoule commented ·
Thx. It looks dbus is offering all the data necessary.
Unfortunately I seem to have trouble reading out any values:
root@ccgx:~# dbus -y com.victronenergy.system/Ac/ConsumptionOnOutput/L1/Power GetValue
root@ccgx:~#
And omitting -y is even more adventurous.
root@ccgx:~# dbus com.victronenergy.system/Ac/ConsumptionOnOutput/L1/Power GetValue
Traceback (most recent call last):
  File "/usr/bin/dbus", line 302, in <module>
    bus = dbus.SessionBus()
  File "/usr/lib/python2.7/site-packages/dbus/_dbus.py", line 211, in __new__
    mainloop=mainloop)
  File "/usr/lib/python2.7/site-packages/dbus/_dbus.py", line 100, in __new__
    bus = BusConnection.__new__(subclass, bus_type, mainloop=mainloop)
  File "/usr/lib/python2.7/site-packages/dbus/bus.py", line 122, in __new__
    bus = cls._new_for_bus(address_or_type, mainloop=mainloop)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NotSupported: Using X11 for dbus-daemon autolaunch was disabled at compile time, set your DBUS_SESSION_BUS_ADDRESS instead
Still sitting here on 2.33, but that shouldn't be the problem - should it?
I should mention that dbus-spy seems to work well, so it doesn't look like the system would be broken or something. Just the method getting info via shell doesn't work for me.
petajoule answered ·
root@ccgx:~# dbus -y com.victronenergy.system /Ac/ConsumptionOnOutput/L1/Power GetValue
443
A space a day, keeps dbus at bay.
mihair avatar image mihair commented ·
If you wanna get something like 433 W, then use GetText instead of GetValue
petajoule avatar image petajoule mihair commented ·
GetValue is fine, as we need to make comparisons of the value (arg1 -ge arg2) etc.
Still fighting here to use dbus-send directly instead of dbus -y, as the latter is slow as ... metabolism result.
A few more questions remain:
How's the return value after a SetValue to be interpreted?
root@ccgx:~# dbus -y com.victronenergy.system /Relay/0/State SetValue 1
0
Or here:
root@ccgx:~# dbus -y com.victronenergy.system /Buzzer/State SetValue 1
2
And how can one make sure the value set also remains set?
e.g. setting that buzzer, it blips shortly and is then off again. Haven't checked the relay, but I assume that wil lbehave the same?
What is ESS training video
ESS Quick Installation Guide
ESS design and installation manual
