sesshoumaru avatar image
sesshoumaru asked
Quattro AC-out control
This may sound like a weird question, ... I understood from the Quattro's documentation that AC-2-out is only supplied with power if either AC-in-1 or/and AC-in-2 have an active source connected. However, can this be changed or is it fixed that way?
I idea would be that in case of grid failure (AC-in-1, AC-in-2 being genset off by default) the Victron system checks if it can supply both AC-outs and if so, both stay on. If one inverter (3-phase-system) is going to overloaded, then AC-out-2 is dropped.
Once AC-out-2 is dropped, I would like to ensure that once at least one AC-in is back (e.g. Genset kicks in) or I decide manually to try, that AC-out-2 is put back on. Is that possible (maybe with Assistants) or too far-fetched?
As always, thanks for taking time :)
MultiPlus Quattro Inverter ChargerESS
snoobler avatar image
snoobler answered ·
sesshoumaru avatar image sesshoumaru commented ·
Thanks, looks good - will try it out.
