jon-norberg avatar image
jon-norberg asked
Cerbo temp sensor scale
My temperature sensors are off on my Cerbo. So I adjusted them in room temperature with offset. But now thay are off when its cold outside. So I need to scale them. Around what temperature is the scale placed? The scale has to be 1 somewhere. The first that comes i my mind is that its around 0 degrees. But it could also be something else?
0 degrees x 1,2=0
4 degrees x 1,2 =4,8
So zero is the most mathematical logic?
cerbo gxTemperature Sensor
