I have a Venus GX with 2 MPPTs SmartSolar. How much VE-Direct Cables I need? Because the MPPTs communicate over BT. Is one Cable enough to get all data to the GX?
You need two VE.Direct cables, one for each MPPT to the CerboGX.
MPPTs do not communicate with CerboGX over Bluetooth.
Bluetooth on the CerboGX is to facilitate initial configuration from a smartphone.
28 People are following this question.
