asimko avatar image
asimko asked
VE Configure 3 grid code selection password
I was able to setup grid code standard to Europe without password with VE Configure 3 on a "remote" file, but now if i want to disable it and set it to "none" it always ask me for a password, that is a bug right?
how to disable it again without the password? i cannot allow feedin, but i was playing first with ess and there was a must to have gride code specified...
grid
sesshoumaru avatar image
sesshoumaru answered ·
You may watch this video: https://www.youtube.com/watch?v=sl1EKKmQNCo
Maybe you see somethong around timecode 01:13:20
rmaddy avatar image rmaddy commented ·
The video is marked as private and can't be viewed.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ rmaddy commented ·
Because in the video the grid code password was shown and as I wrote it is not supposed to be public.
The video will be back online someday without the grid code password.
Ask your installer/dealer/distributor about it.
That's not a bug it's a safety feature.
The grid code should not be set or change if you don't know what to do.
There is a warning about that if you change the grid code the first time.
The grid code password is not public.
You should contact your local Victron dealer/distributor about that.
https://community.victronenergy.com/questions/40871/bloody-grid-other-password-are-you-kidding-just-to.html?childToView=40872#answer-40872
asimko avatar image asimko commented ·
OK I understand, but I was setting up a ESS and there was a need to confirm this about grid code so I accepted it. After that I deciced to remove this configuration and I think that is the "bug". Why do I need to code to remove grid configuration? Other way it is ok, but if I want to remove it, it should go without the password. ...
suggarman avatar image
suggarman answered ·
Removing the grid code is the critical part, not setting it!
asimko avatar image
asimko answered ·
For those who are looking for a solution, it can be removed by setting all to default, or by typing the password ...
marconi avatar image marconi commented ·
How can I reset the entire system and get the dealer out of VRM?
lucca371 avatar image lucca371 marconi commented ·
https://www.victronenergy.com/media/pg/Venus_GX/en/factory-reset.html
In the root (top) of VRM you see Preferences-->Dealer.
There you can find a unlink button.
