Rob Duthie avatar image
Rob Duthie asked
Re Multigrid2 & Multiplus2 parallel mode ?
One inverter is Ver # 2625 and the newer one is Ver # 2629
Both are 230v 48/3000watt Mulitplus2 type units.
The 2625 was a Mulitgrid 2 before they changed the name to Multiplus2
What is the difference? can they be paralled or not?
I know you have to have the same first 4 numbers to be compatable to be used in parallel modes
Regards
Rob D
NZ
Multiplus-IIgrid
Matthias Lange - DE answered ยท
And this is you answer.
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
Rob Duthie avatar image Rob Duthie commented ยท
Hi Matthias
I see that the Multiplus2 has a slighty different output relay control loop, in that the way it changes over to the AC in etc.
Compared to the Multigrid2 when i installed it, i was told it was the same type but different name change at that time.
Regards
Rob D
NZ
0 Likes 0 ยท
