dadgumadventure avatar image
dadgumadventure asked
IP65/IP67 Blue Smart Charger not putting out the amps I was hoping for
I am charging a lifep04 280ah 14.4v battery. The charger is only pumping out 2.9 amps and at this rate it will take 26 HOURS to charge. The battery is at 13.6v so I am confused as to why this 25amp charger is not putting the power to the battery. Any help would be greatly appreciated. Thanks Mattimg-2401.png
charger
shea avatar image shea commented ·
Did you choose the LFP charge profile? You should be in Bulk.
Check the wiring. If you have 13.6V at the battery that means you have a voltage drop of 0.8V from the charger to the battery.
