Is there a way I can use the BMV702 to give me a SOC when I use a Pylontech battery with GX device?
Without spending money on a GX screen I would lie to be able to see SOC using equipment I already have
This should help, if you cannot get it from pylontech
https://www.victronenergy.com/media/pg/SmartShunt/en/battery-capacity-and-peukert-exponent.html
It will be shown on the BMV as long as it's wired correctly. But will read/calculate from the shunt not the pylontech.
So confirm I would need to change the Peukert co efficient? Where do I get that for a Pylontech battery?
25 People are following this question.
