The Tank 140 is compatible with either Voltage or current senders.
You can use 4-20mA current senders or Voltage senders with a range of 0V to 10V.
The ranges can be adjusted to suit the particular sender that you decide to use.
If I were to replace these ‘sensors’ with something a bit more high-tech - what would be the best recommended tank sensors for the GX Tank 140?
26 People are following this question.
