Hi I can't connect my blue tooth phone to the inverter and noticed the blue tooth symbol is missing on the display How to I fix this
hello
is it a blue solar or a smart solar MPPT ?
if it's a blue solar, ther's not blue toooth on it, you need to ad a smart dongle BT
Hello @Daring
Is the Smart Solar not visible in VictronConnect or is it for example greyed out and when you press it, it gives a notification?
If it is not visible, are you sure that you have location services enabled on the phone?
When it is visible but greyed, it is necessary to power cycle the MPPT by disconnecting PV and battery for a minute. After reconnecting them (battery first), you should be able to connect again. When you are connected, please install the update to v2.37 that is available in the latest VictronConnect (v5.52), by going into the product info screen.
Regarding the symbol on the display, I am curious what symbol you are revering to as there is not a symbol that shows whether bluetooth is enabled or not.
Kind regards,
Thiemo van Engelen
26 People are following this question.
