radkos avatar image
MultiPlus 12/500/20 can charging small battery?
Can MultiPlus 12/500/20 charging small battery? From spec. I understood that charging current is 20A. I would like charge 85 hA and smaller battery? What will be smallest recommended battery for this 20A charger?
battery charging
kevgermany avatar image
kevgermany answered ·
Ideal max current is 0.2C for lead. Where C is the battery capacity. Higher charge rates will shorten battery life. You're slightly over this rate, starting size would be 100AH. If you're not discharging too deeply, it will probably be OK as the battery will limit the charge current.
JohnC avatar image
JohnC answered ·
Hi @radkos
If you have access to the Multi's settings, you can lower the stock Charge Current Limit to whatever you desire..
