rostislav avatar image
rostislav asked
Multiple Multiplus in parallel connection
I have one Multiplus 24/3000/70-16 on my boat and want to install another one and configure to work in parallel. The problem that I found yesterday that I bought 24/3000/70-50 (50A max AC current). Will they still be able to work in parallel?
Many thanks in advance.
multiplus in parallel
Alexandra avatar image
Alexandra answered ·
@Rostislav
In the manual, its states:
All units in one system must be the same type and firmware version, this includes same size, system voltage, and feature set. The type is indicated by the first four digits of the firmware version number. For details, see the “VE.Bus Firmware Numbering System” section in the VE.Bus Firmware versions explained document.
Parallel systems can be a bit fussy. There are different hardware revisions even between same models. So you would need to assess whether you can using that info.
