elel avatar image
elel asked
SoC jumped to 100% while the battery was being discharged
I have the following simple setup with ESS Assistant in which I charge the battery from the grid during low rate period at night and then use the battery for the house loads during day time.
I encountered a problem in which the SoC shown in the VenusOs screen jumped from 69% (Main On+Absorption LED “ON”, Inverter On LED “Blink”):
suddenly to SoC 100% (Main On+float LED “ON”, Inverter On LED blink):
while the battery was being discharged!
The battery pack has its own BMS and the BMS has no connection to the MP-II.
I set the "State of charge when Bulk finished " to 90% in VEConfig and it worked properly.
I set the "Minimum SoC (unless grid fails)" in ESS to 10% and it worked properly.
The “Float Voltage” set in VEConfig was 52V. The above problem occurred at 53.2V .
Any advice on:
Why the Float LED suddenly lighted up?
Why the SoC suddenly jumped to 100%?
SOC
Paul B avatar image Paul B commented ·
Hi we would need more setup information to be bale to help you
Please send setting pictures on the Muttiplus ve configure settings one screen shot for each of the screens - also in the GX please send the system setup setting showing the battery monitor selected
elel avatar image elel Paul B commented ·
Thanks a lot for the response. Below are the settings exported from VEConfig:
TAB: General
System frequency 50Hz
Shore current 100.0 A
Overruled by remote unchecked
Dynamic current limiter unchecked
External current sensor connected (see manual) checked
State of charge when Bulk finished 90.0 %
Battery capacity 277 Ah
Charge efficiency 0.95
TAB: Grid
Country / grid code standard UK: G98/1 March 2019, G99/1 May 2018
LOM detection AC input 1 Type B (grid code compliant)
start P(f) at 50.40 Hz
start delay for p(F) 0.08 s
Droop for p(F) 10.0 %
Use Aux1 (if available) as disable FeedIn signal checked
Reactive power regulation Use a fixed Cos Phi
Filter time for reactive power 3.3 s
Cos phi at point 1 1.00
TAB: Inverter
PowerAssist unchecked
Inverter output voltage 230 V
Inverter DC shut-down voltage 48.00 V
Inverter DC restart voltage 50.00 V
Low DC alarm level 49.00 V
Do not restart after short-circuit (VDE 2510-2 safety) unchecked
enable AES unchecked
TAB: Charger
Enable charger checked
Weak AC input unchecked
Stop after excessive bulk checked
Lithium batteries checked
Configured for VE.Bus BMS unchecked
Charge curve Fixed
Absorption voltage 55.00 V
Float voltage 52.00 V
Charge current 70 A
Repeated absorption time 1.00 Hr
Repeated absorption interval 7.00 Days
Absorption time 1 Hr
TAB: Virtual switch
TAB: Usage
Virtual switch usage Do not use VS
TAB: Assistants
TAB: Assistant Configuration
ESS (Energy Storage System) (size:962)
*) System uses LiFePo4 with other type BMS
(This can be either a BMS connected via CAN bus or a BMS system in which the
batteries are protected from high/low cell voltages by external equipment.)
*) The battery capacity of the system is 277 Ah.
*) Sustain voltage 49.00 V.
*) Cut off voltage for a discharge current of:
0.005 C= 48.00 V
0.25 C= 48.00 V
0.7 C= 48.00 V
2 C= 48.00 V
*) Inverting is allowed again when voltage rises 2.00 V above cut-off(0).
*) Relevant VEConfigure settings:
- Battery capacity 277 Ah.
- PowerAssist unchecked
- Lithium batteries checked
- Dynamic current limiter unchecked
- Storage mode unchecked
Below is the screen for the "Battery Monitor" :
Here is the video showing the sudden jump to 100% SoC.
https://drive.google.com/file/d/16hqb87Ce6e9MNH_LlkQA6yIPiyxORBO8/view?usp=sharing
Look forward to your advice on this problem.
(Note: I also have some other problems encountered:
https://community.victronenergy.com/questions/113770/discrepancy-between-grid-setpoint-and-the-actual-p.html
I am not sure whether they are related.)
elel avatar image elel commented ·
The same problem happened again today in which the SoC suddenly jumped to 100%SoC.
After the sudden jump-to-100%-SoC problem last night, the system failed to execute the scheduled charging after mid-night and then did a list of erroneous actions after that…… (but these are not the subject of this thread and I will handle them later, just in case they are related to this one).
I somehow was able to schedule the changing during daytime. The battery then discharged as expected but then jumped to 100% SoC from 80% just like what it did last night. Here is the link to a short video which shows what happened.
https://drive.google.com/file/d/1NUdbynsnhQS0EemTmcZi3BBPSp2uKSzK/view?usp=sharing
Any help or advice would be very much appreciated.
(Note: after the setup of the ESS, it was the 2nd time I discharged the battery from the end-of-bluk-charge status and in both cases this problem occurred.)
Paul B avatar image
Paul B answered ·
If you look at your video you will notice that it switched from Absorption to float on the multiplus loghts then the SOC flipped to 100% -
So I would think that the Multiplus was ending the absorption phase of its charging cycle as its held the battery voltage at 55v for 1 hr as set and is now changing to float mode of 52v, at that point the SOC is changed to 100% as the battery is full.
The small discharge is occurring because the absorption voltage is 55volts and float is 52 so you will see a negative amps figure until the float voltage reaches the set point set being 52 volts.
well thats my thoughts as to why
