Hello, is it possible to upgrade firmware from 2610xx to 2612xx ?
The are both multis...
2610 --> MultiPlus 24/3000/70-50 (+EasySolar)
2612 --> MultiPlus 24/3000/70-16
Thanks
Markus
Thanks
Markus
The first 4 numbers are the hardware ID and the last 3 are the firmware version.
You can't change the hardware with a firmware update.
https://www.victronenergy.com/upload/documents/manual-VE.Bus-firmware-versions-explained-EN.pdf
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
26 People are following this question.
