Manual start generator at present.
Sorry, but you need to tell us more.
Is there anything else in the system?
What do you mean by generator drops out. Is that stops running, or stops charging?
Afik there's no way for what you've described to control the generator.
Easy solar 48/5000/70-10,smart solar MPPT 150 /100 , 9 x 300w solar panels, 4 Exide batteries EP2100, Generator diesel . We are off grid so generator is supplemental to the solar. Generator is manual on/off, relay started cutting out after minutes then seconds now it wont charge batteries at all. We also only have mobile internet so not able to use remote victron connection . Thanks
What conditions did you setup for the relay to start the generator?
I'd suspect the relay or a wiring issue as first things to test, both easy to check. But your comment about resetting to defaults makes me think you should try and get the people who set it up back to trace the problems.
GX - Generator auto start/stop
Automatic Generator start/stop
37 People are following this question.
