Has anyone found a way to stop the VE direct plugs dropping off - they seem quite weak compared with other connections on my boat electrics and electronics.
When I was dealing with these kinds of connectors in a commercial environment, we would use a small drop of non-flowable RTV (silicone) about the size of a grain of rice to hold them together. Just enough to hold the connector together, not so much that you couldn't easily pull the connector apart later when needed.
28 People are following this question.
