sv-kesh avatar image
sv-kesh asked
Schematic Recommendation
I’m in the process of upgrading the system on my sailboat and a little overwhelmed by the complexity of most of the schematics from Victron. Can’t seem to find one that closely resembles what I’m trying to do.
-1 lead acid start battery
-100 amp internally regulated alternator
-Orion 12-12 30 amp isolated DC-DC charger
-2 206Ah Lithium batteries w/ integrated BMS
-1 Multiplus 3000 12v inverter charger
-2 Victron MPPT charge controllers to be added (planning two arrays totally approx. 600 watts)
-Cerbo GX
-Both AC and DC
Can someone point me in the right direction in terms of an appropriate schematic?
Thanks in advance!
MPPT SmartSolarorion-tr smart
seb71 avatar image
seb71 answered ·
Since you are still at the planing stage, if you did not bought anything yet, you should consider going for a 24V or, even better, for a 48V system. It is more suitable for a 3000VA inverter than a 12V system.
sv-kesh avatar image sv-kesh commented ·
Maybe on my next boat. I have already purchased and installed the 12 volt Multiplus so committed down this path for now.
