Meiring avatar image
Meiring asked
Can a new easysolar run parallel with an older multi with new 3000C pylons as on pack without bmv
Easyolar is model 2020 other is about 6 years older single phase system off-grid with 12kw pf1 gen calibrated.
multiplus in parallel
Paul B avatar image
Paul B answered ·
yes as long as both units have the same starting fw number Ie both start with 19 or 26 (220 volt versions) same for 110 as well but different numbers but both have to be the same
also the unit has to have the same size pass through relay and they would then need to be setup in parallel (and properly configured) a GX device would be HIGHLY recomended
So its NOT a straight yes or no its a maybe
