codematic avatar image
codematic asked
BMV-712 ve.direct worked fine until i added the temperature sensor, now transmits garbage ?
Greetings,
my BMV-712 is installed with the victron shunt. There is a ve.direct connection via the victron USB cable to a Raspberry PI. The text output from the ve.direct has been working flawlessly for a few weeks.
I added a temperature sensor today, and now it only transmit garbage. If i remove the temperature sensor i still see no text display, just random data.
Anyone have any thoughts on whats going on ?
Thanks !
-Lenny
BMV Battery MonitorVE.DirectTemperature Sensor
codematic answered ·
Ok i got it to work again, i had to reset everything. and it came back.
kevgermany avatar image
kevgermany answered ·
What temp sensor and how did you connect it?
