sbkenn-ie avatar image
sbkenn-ie asked
Economical solution wanted: Solar, wind and diesel-generator, charge management.
Approx 1.5kW (theoretical) Solar, 2kW Wind, 3kW from diesel CHP (only when required), 17kWatt.hour battery.
I want to heat water with excess power, so wind-power should be harvested rather than stopped in high winds.
I will be using "ideal" diodes on both charge and discharge sides of each battery pair (24V) to prevent degraded batteries from killing their neighbours.
TIA.
Shane
Digital Multi Control
