jim-gravel avatar image
jim-gravel asked
What gauge wire / ferrule size should I use in the tank sensor terminal block connector on Cerbo GX?
Section 2.8. of the Cerbo GX manual talks about Connecting Tank Level Sensors. "To physically attach the tank probes requires a ferrule or exposed copper end of at least 10 mm+ to be inserted into the removable terminal block connector."
I want to add a ferrule to the wire that connects to my tank level sensor that can then be input into the terminal block connector.
What gauge of wire or ferrule size is recommended for the terminal block connector?
Thanks in advance... Jim
cerbo gxterminals
devodave avatar image
devodave answered ·
I could not locate ferrules long enough to be grabbed by those connectors. I had to resort to tinning a longish length of wire.
pwfarnell avatar image
pwfarnell answered ·
I found some 1.0mm² and 1.5mm² extra long bootlace ferrule crimps that were 18mm long on UK ebay, I think I used the 1.0mm² ones in the end as the wires were 0.75mm². This length fits the terminal blocks on the Cerbo GX as I used it for the temperature and digital inputs on that as well as on the GX Tank 140 as shown.gx-tank-140.jpg
See attached links, you may be able to find smaller packs.
https://www.ebay.co.uk/itm/121374722273
https://www.ebay.co.uk/itm/120972486712
raymiller avatar image
raymiller answered ·
Careful in connecting the ferrules into the connector, highly recommend you depress the tensioning spring with a small screwdriver before you insert the ferrule, then release. The internal connector spring can be easily damaged by forcing the ferrule in and Victron does not stock connector spares. I have an order from Element14 16weeks and counting..
wkirby avatar image
wkirby answered ·
RS also stocks 12mm long ferrules: https://uk.rs-online.com/web/p/bootlace-ferrules/2503422
I have not tested yet, but I think the Phoenix DFMC series of connectors are compatible.
