peter-davies avatar image
peter-davies asked
Adding a Runtland 914 wind turbine
just wondering, I have a BMS12/200 for the alternator, a Multiplus and some solar panels with an MPPT controller.
I know the alternator, multiplus and MPPT have to go to the LB terminal of the BMS but if...
I put a rutland 915 wind turbine with its own controller onto the system does the negative from the controller also have to go to the LB of the BMS?
Thanks
BMS
