Can I put a Lithium Battery and a Multiplus in the same box or compartment?
Yes.
You used to have to separate the battery and inverter with lead acid because of the corrosive/ explosive off gassing. This no longer applies with lithium.
The only other considerations are if the inverter is working hard and the temperature in the compartment rises. Just make sure it stays within manufacturer operating range.
54 People are following this question.
