mxride avatar image
mxride asked
Qty 4 12volt Batteries Wired for 24volt Output
Just a quick question. So on my motor coach, the starter requires 24volts. It has qty 4 12volt batteries wired for 24volts output. I'm looking to get a Victron charger, and wondering if I should have get the 24volt charger or the 12 volt charger. I assume the 24volt charger put wanted to clarify with all you smart folks.
Thanks in advance
battery charging
kevgermany avatar image
kevgermany answered ·
24, simply the 12V will not work
Just think of it as two 24V batteries. Each one in two parts.
