Running 300Ah of LiFePO via 100/50 64V 9.6Amp 600W Solar Array in Trailer to 12V Multiplus 2Kw.
You'll have to give more info. Like where are you seeing the low voltage ac or DC, what does the battery have, what readings are on the mppt. More the better
49 People are following this question.
