solartech avatar image
solartech asked
Which size of the victron mppt charge controllers should I need if i want to use it with single solar panel JA solar 500w ? The battery to be charged is pylontech 48v 2.4kw
Which size(model) of the victron mppt charge controllers should I need if I want to use it with just single solar panel JA solar 500w ? The battery to be charged is pylontech 48v 2.4kw , inverter is going to be 48v | 500 VA Phoenix. Do i need also to use cerb gx ?
Thanks
MPPT ControllersSolar Panel
hjohnson avatar image
hjohnson answered ·
Your solar array needs to have a voltage at least 5V higher than the battery setup. What voltage is your proposed panel?
klim8skeptic avatar image
klim8skeptic answered ·
Unfortunately a single JA 500w solar panel does not generate a high enough voltage to charge a 48v battery.
You are going to need an 150v charge controller (input voltage) and 2 panels in series.
Use Victron online MPPT calculator. to see what panels/mppts are suitable.
MPPT Product Page
MPPT Error codes
