Hi, New to the group. How do you find an Victron installer/engineer in the UK please. North West England ideally.
Thanks, Clay
Take a look at this map:
Hello Connor,
Are there any installers in London please to install a battery and inverter?
Thanks
Good luck having the same issues in Buckinghamshire, seems lots of people sell the kit but getting the install done is a lot harder. I’m looking at getting a local spark to do the install as the mains needs to be rerouted and then hopefully as if by magic getting a Victron installer to commission the install but I’m a good couple of months out before that
If you find one please share it with us, interested in one covering Hertfordshire...
Ended up doing the install myself with the mains run by my cousins who are sparks, ive temp wired the Cerbo just so I can set it up should have the inverter next month. Need to do more wiring for the inverter but most if not all of the hard wiring is done now just need crimps to finish the 120mm2 cable
best of luck with your install daza, do let us know how you get on.
Must confess I'm curious as to your PV system, panels, inverters, MPPTs etc but guess that's for another thread...
Are you exporting to the grid ?
Thanks. PV is Solis AC that’s feed from the houses CU then loops to the garage then to the grid, 3.2kW array all black panels. Yes the PV is exporting to the grid it was installed by an MSC installer so I’ve not changed anything on that I just added the split CU with 25mm 5core cable so the garage is now where the mains goes.
it’s getting there!
31 People are following this question.
