michelg avatar image
michelg asked
BlueSmart Charger 24V for LiFePo4 ?
Hello everyone !
I own a LiFePo4 battery "24V" 768Wh (30Ah), whose PSU is dead. Is it possible to use a BlueSmart charger in Li-Ion mode to recharge it ? If yes, which model is recommended to recharge it fast ? Also, which model will fitt my needs, as I need to recharge it as fast as possible. The PSU was able to recharge it to 80% in 1h, and full in less than 2h.
It has its own BMS. Thanks,
Michel
charger
kevgermany avatar image
kevgermany answered ·
Maybe it's a blown internal fuse. Or BMS.
You might have to remove the existing PSU/charger.
25A would give similar charge rate.
Really needs a technical examination.
michelg answered ·
@kevgermany Thanks for the reply. Long short story, my Ecoflow R600 Pro died, and fighting with Ecoflow since 27th of September to get the things fixed... As they don't give a s..t , I may be forced to dismantle it, and rebuild my own system using the Victron SmartCharger and an inverter to make my own system...
Michel
Bad do. Good luck.
