scott-rosenberger avatar image
Virtual Switch/Assistants tabs not available in VEConfig
New marine install...
Can't get VEConfig to show "Virtual Switch" or "Assistant" tabs...
2 Quattro 24/5000/120-2x100 120V (Two units configured as split-phase) Firmware 487 (Input 1 Shore Power --- Input 2 Generator)
Cerbo GX Firmware 2.73
Multi Control
50 Touch Display
3 SmartSolar 100/20 48V Firmware 1.59
4 Orion TS Chargers Firmware 1.06 (Charging AGM Batteries)
8 Lithium 12V 270A batteries
I wish to activate the 4 Orion Chargers whenever the Quattros have incoming AC power using the Quattros Relays
Additionally, I'd like to activate the generator any time battery voltage is less than (some predifined) voltage.
Any help would be greatly appreciated...Scott
Assistants
Alexandra avatar image
Alexandra answered ·
Are you using a PC? @Scott Rosenberger
There is ve config and victron connect.
Assistant programming is not avalailable in victron connect yet. Assistant tab is only available if virtual switch is not active in ve config, when you tell it not to use virtual switch.
So you have to choose one or the other.
You can do something similar to virtual switch with the generator assistant
All the basic assistants are listed here.
For practicing or exploring options set up a demo product in ve config and see what options you have for your idea. It is mentioned in one of the manuals how to set up a test product without setting up a physical one.
Can you make a screenshot of your VEconfig?
It should be look like that:
scott-rosenberger answered ·
Ahhhh...got it!
Because of the "split phase", I needed to use VE Bus System Configurator first and it then takes me into VEConfig3
