tenacioustech avatar image
tenacioustech asked
Cerbo GX & Pylontech LV-Hub Issue
Howdy Guys, I’ve got 2 Pylontech US2000B+ strings wired via CAN bus into a Pylontech LV-Hub. Then using the Victron cable from LV-Hub CAN output into the Cerbo GX BMS-CAN connection.
While running the LV-Hub on v1.1 this was working ok, though felt it was lacking data. As the Pylontech batteries have a lot more data than the Cerbo was displaying.
So I decided to update all the firmwares to current.
After this, I found the Cerbo was no longer seeing any Pylontech batteries via the LV-Hub. I can see on the Cerbo that there are CAN packets moving around both TX and RX.
Is this likely just a matter of the Cerbo not accepting v1.7 firmware of the LV-Hub?
Any help, greatly appreciated!
Cerbo running latest firmware v2.73
Victron system is a Quattro 15000, 2 x MPPT 450/100, Cerbo GX with Colour Touch.
Lithium BatteryPylontechbattery
Rob Duthie avatar image
Rob Duthie answered ·
How did you update the LV Hub firmware with what interface and Bin files?
Victron Pylontech battery compatibility guide
Battery Compatibility
