upsy avatar image
upsy asked
VRM api via axios/ nodejs ? code exemple ?
Hello I'm trying to connect to VRM portal via axios / nodejs / vuejs
but I'cant find exemple of code.
I get the token & userId but after the token no longuer seem valid for other end points ?
when I use token in header with header :
   var headers =
   'Authorization': 'Bearer ' + token
https://vrmapi.victronenergy.com/v2/users/***myUserId****/installations
Apti return 401.
Some ideas/exemples please ? thanks by advance
Yann
my code (login)
const params = {
'username': '******@gmail.com',
'password': '******',
const header = {
'Content-Type': 'application/x-www-form-urlencoded'
 * call via axios
 await Axios.post('https://vrmapi.victronenergy.com/v2/auth/login/', params , header).then   ((resp)=>{
 return resp
 /** return
*response": {
    "Token": "eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiIsImp0aSI6IjdkZTcw******************"
    "idUser": *****, // ok
    "verification_mode": "password",
    "verification_sent": false
 }).catch((err) => console.log(err.message));
VRM
westcott avatar image
westcott answered ·
Hi Upsy,
This seems to work -
"X-Authorization": "Bearer " + token
Found that by looking in the Victron Node-Red code.
