sac-rv avatar image
sac-rv asked
Multi Control doesn't seem to be working
I went up to the trailer yesterday for the first time in a couple of weeks. I noticed none of the Charge only / Off / On modes appears to be working. There are no LED indicator lights illuminated and the current limit can’t go above 16, regardless if the generator is on or not. It can be turned down zero. The inverter appears to be working fine, although the charging was slower due to the current limit.
Any thoughts on the issue?
Digital Multi Control
@Sac RV
The data cable?
sac-rv avatar image
sac-rv answered ·
I unplugged the data cable on the back of the Multi Control and plugged it back in. That seemed to work and back to normal operation.
