bitcrusher avatar image
bitcrusher asked
230V Relais for digital output
Hi there,
I have a cerbo in my RV and want to control a 230V awning socket / outside plug via the digital output Relais.
can you recommend a corresponding 230V Relais for that?
Thank you!
Relay
bitcrusher avatar image bitcrusher commented ·
Maybe a Shelly Relais?
Is there a possibility to switch a 230V Bluetooth / wlan Relais via cerbo?
Paul B avatar image
Paul B answered ·
You could use the internal assistants to turn AC2 out on/off using AUX1 or Aux 2 to trigger this - thats if you are not using ac 2 out for other stuff but then this is using a multi/quattro unit
or for the cerbo if you are NOT using the gen autostart then you could use that cerbo relay
or there are plenty of high/low control relays 5 12 and 24 volt that you could also use
Click here to see a link that will take you to a ebay item that MAY help
