In the manual it says you can connect a charger to the System+ port, in my setup it does not charge.
Loads connected to the System+ port are working.
What is wrong?
What is wrong?
@Peter Buijs - NL When charging through the System + port, what is the status of the LED beside it?
Have you connected to it via the Victron Connect App? It looks like there was a firmeware update for these issues in Victron Connect v5.39 issued on 12/04/21. Do not know if the updated firmeware version will help, or there is some configuration in Victron Connect to help.
25 People are following this question.
