dukeofhazard avatar image
dukeofhazard asked
Newby needs help with orion dc-dc charger on lifepo4
Hallo, I have a persistant problem with my setup. Somtimes the voltage of the lifepo4 falls under a treshold to which the BMS shut down the akku output. After that the orion 12/12-18 does not load the akku at all - the charger cannot heave the akku over that treshold again. Other chargers can. I have a small dedicated lifepo4 charger that does the job without problems.
Settings on the orion are all set to lifepo4.
Does anybody have experienced similiar problems, and maybe found a solution?
I 'am grateful for any hints...
Lithium BatteryOrion DC-DC Converters not smart
kevgermany avatar image
kevgermany answered ·
Any LEDs on on the charger?
Have you checked with Victron connect?
What voltage does the BMS show?
Guessing that the Orion thinks no Akku or faulty Akku.
