miya avatar image
miya asked
Transferring ownership of Venus GX
Hi All
I am in the process of selling my yacht - and the full Victron install will be going with the yacht to a new owner - including the Venus GX.
I assume I delete the Venus GX install from my VRM accounts, the new owner creates a VRM account - and then add the Venus GX to his VRM account - and that is it ?
Can anyone point me in the right direction - what steps I should take ?
Thanks,
Tim
Venus GX - VGX
Alexandra avatar image
Alexandra answered ·
@Miya
Yes that will work.
You can also invite the new user with their email address to the install, set them with admin rights and delete yourself or they remove you. I have found this way work better. There is often less issues for the new user especially if they are unfamiliar with the system.
miya avatar image miya commented ·
Hi Alexandra
Thanks - your suggestion sounds perfect - everything will just be there waiting for the new buyer - and I can show him around, Perfect - thanks !
Once he has removed my email address... do you know... will I then be able to create a new VRM account with my old existing email address - for use with the new yacht I am getting ?
Thanks
Tim
Alexandra avatar image Alexandra ♦ miya commented ·
Your vrm account will still exist as it is. You can have loads more than one install on it at a time. And you can use it as is with the next install or gx you connect to.
