sando avatar image
sando asked
Need help with new set up
I'm just about to start converting a van that has a smart alternator I already own a victron smart solor mppt I'm wanting to use lifepo4 batteries as my lesure set up so need to know which product I need to add to it that has a built in bms
Kind regards
battery charging
Alexandra avatar image
Alexandra answered ·
@Sando
There are plenty resources on you tube.
If you are planning to charge from solar and the alternator there are quite a few automotive products at your disposal depending on your system design aims. You will need to decide whether you are using Dc loads and ac loads and a few other things
Its quite a big project to take on, also find a local dealer to develop a good relationship with and get advice from, easier to get back up that way.
