semaphore avatar image
semaphore asked
Battery Protect not waiting 90 seconds
I have a Battery Protect 220. The loads are all on the correct side.
I have a charger/inverter (not victron, sadly) and that is not protected with the battery protect because it's a charger. Thus, I was hoping to use the relay contact on the BP to disconnect the charger/inverter. I haven't done that yet.
The issue is when the charger/inverter line is reconnected, the BP disconnects and reconnects. It does not wait 90 seconds. It does not display anything on the segment display. Neither the BP nor the smartshunt register a drop in voltage. I don't have an ammeter capable of measuring the inrush current.
Any ideas?
Lithium BatterySmartShuntBattery Protect
Victron BatteryProtect product page
Battery Compatibility
