immanuel avatar image
Connecting 123SmartBMS to Phoenix Inverter Compact
Dear victron-community,
I would like to turn my Phoenix Inverter Compact On and Off with my 123SmartBMS to protect miy LiFePO-batteries. Unfortunately the inverter doesn´t have auxiliary inputs as the new multi- or quatro-models have. So my question is the following:
Can I use the remote connector on the Phoenix Inverter Compact for remote switch to controll it with the load-relay of my 123Smart BMS?
Has anybody experience with it? In the FAQ of the 123SmartBMS there is a section on "How to control a victron device.". Unfortunately the use case for a Phoenix Inverter Compact is not well elaborated. A video on youtube shows that it is possible with a Phoenix Inverter but doesn´t explain how the connection is made.
Here are my sysem specifications:
Inverter:
Battery Management System:
Battery:
Phoenix InverterBMS
nebulight avatar image
nebulight answered ·
I know that the main physical on off switch, I believe has a connector on the inside that you can wire the allow to discharge relay to from the 123smartbms, but I don't have a phoenix to look and see.
immanuel answered ·
Hello @nebulight, thank you for your response.
The only possible connector that my Victron Phoenix Inverter Compact 24V/2000VA-230V has for this is the "Connector for remote switch" which consists of 3 pins CH, COM and IN (see Appendix A, Connector L in Inverter Manual on p.115).
But in all explanations from victron that I could find regarding the controll of an inverter by an external non-victron BMS, they always talk about connecting to the aux-input (refer to "Connecting other lithium systems to Multis and Quattros-Manual").
Since my Inverter is not a Multi or Quattro, it doesn´t have an aux-input but just the "Connector for remote switch" which is intended for a remote three-way-switch. So in theory it should work to take the BMS-Relays instead of a physical three way switch. I´m just concerned because I can´t find any explanation or wiring diagramthing about it.
So basically my question boils down to this:
Is it possible to control a victron inverter by an external non-victron BMS (in my case 123SmartBMS gen3) using the inverters "Connector for remote switch". If yes, how is the exact wiring?
