finalshare avatar image
finalshare asked
Running a MPPT 150/100 at 160 Volt bad?
Hi, i have a Victron 150/100 with 3x LG Neon R 370 watt solar panels rated for 370 watts at 37 volts and 10,01 amps
thing is, that should be 1110 Watts of solar but i often get 1200 and even 1300 watts for more than half an hour thats 120 Volts at 10 Amps
im thinking of putting a 4th panel on the roof
That would be 1480 watts with 148 volts at 10,01 amps
Theoretical ok as datasheet states
but im expecting it would also over-deliver at 160 Volts- 10 amps
thast 10 volts over rated voltage of the expensive Victron Unit.
Will this cause problems?
MPPT ControllersMPPT SmartSolarSolar Panel
marekp avatar image
marekp answered ·
YES.
This will kill your MPPT.
If you want 4 panels make it 2s2p.
7 comments
finalshare avatar image finalshare commented ·
damn... that would be 80 Volts at 20 Amps
now im fearing performance lost with high amps and heat loss also 80 volts will decrease my eficiency i guess.
thats too bad..
could i hook up a Weaker Panel from the Same Brand in series ?
like 3x 40 and 1x 20 Volts to get to a maximum of 140 volts? or will this disturb the panels
marekp avatar image marekp finalshare commented ·
Panels in one string needs to be identical.
What is your battery voltage?
finalshare avatar image finalshare marekp commented ·
48 volt pylontech
If you have 48V battery why did you buy 100A MPPT?
Did you use this calculator?
https://www.victronenergy.com/mppt-calculator
i had a 12 volt system before and now i upgraded to 48 volts, earlier i needed the 100amps
but now i messured again... seems like i cant even fit the 4th panel . sadly
If I were you, I would go now with 2s2p if now you have only 4 panels,
Later I would make it 3s2p. (6 panels)
Further upgrades would have to be 3s3p, 3s4p up to 3s7p.
Only do not wait to long with the upgrade because you might have a problem getting same panels later. They go off the market fast and are replaced with new models.
Edit:
I just noticed that you have no room for more than 3 panels, so my suggestions a useless.
But thanks for your help anyway!
gro avatar image
gro answered ·
I think any efficiency loss will be more than made up for by the extra energy you will collect with 4 panels.
If you want more panels you can have a 3s2p array.
Don’t play with different panels, it is not advised that you mix panels. I certainly would avoid different wattage panels in a series string.
so you mean 3 panels in series and then the 3 panels + 1 panel in paralel? is that doable?
kevgermany avatar image kevgermany ♦♦ finalshare commented ·
I think that will kill any output from the single panel.
