Ulrich avatar image
Ulrich asked
request to https://vrmapi.victronenergy.com/v2/auth/login failed, reason: certificate has expired
I could not login to VRMAPI.
If i click on "LOGIN" my Dockermachine victronenergy/venus-docker-server says:
Wich certificate? How could i generate a new one?
[info] [vrm] Logging In
(node:1) UnhandledPromiseRejectionWarning: FetchError: request to https://vrmapi.victronenergy.com/v2/auth/login failed, reason: certificate has expired
    at ClientRequest.<anonymous> (/usr/local/lib/node_modules/venus-docker-grafana-server/node_modules/node-fetch/lib/index.js:1455:11)
    at emitOne (events.js:116:13)
    at ClientRequest.emit (events.js:211:7)
    at TLSSocket.socketErrorListener (_http_client.js:401:9)
    at TLSSocket.emit (events.js:211:7)
    at emitErrorNT (internal/streams/destroy.js:73:8)
    at _combinedTickCallback (internal/process/next_tick.js:139:11)
    at process._tickCallback (internal/process/next_tick.js:181:9)
(node:1) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
(node:1) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
VRM
Ulrich avatar image
Ulrich answered ·
Yes, it is fixed. They have installed a new certificate.
Ulrich avatar image
Ulrich answered ·
Did you (victronenergy) changed the minimum TLS Version of the VRMAPI Server?
On the docker machine i found wget. Look here:
# wget https://vrmapi.victronenergy.com
--2021-10-04 14:09:57--  https://vrmapi.victronenergy.com/
Resolving vrmapi.victronenergy.com (vrmapi.victronenergy.com)... 3.127.228.28
Connecting to vrmapi.victronenergy.com (vrmapi.victronenergy.com)|3.127.228.28|:443... connected.
ERROR: The certificate of 'vrmapi.victronenergy.com' is not trusted.
ERROR: The certificate of 'vrmapi.victronenergy.com' has expired.
# wget --version
GNU Wget 1.18 built on linux-gnu.
openssl has Version 1.1.0l
It should support TLS 1.2....
Please help.
Ulrich avatar image
Ulrich answered ·
Ahhhh.
Look here: (ssllabs.com)
One of your certificates has expired. My System has stopped at 2021-10-01 2:35 ...
(https://www.zoomsoft.de/grafana/d/zsbw/banu-womo?orgId=1&refresh=10s&from=now-7d&to=now)
Ulrich avatar image
Ulrich answered ·
Ulrich avatar image
Ulrich answered ·
pau1phi11ips avatar image
pau1phi11ips answered ·
