mr-s avatar image
mr-s asked
No solar input on Cerbo from Easysolar II GX
I have the Easysolar II GX 48v/3000/ 250/70. I have connected a Cerbo gx. The cerbo shows battery and ac loads but not solar. I have connected the cerbo to the Easysolar via Ethernet cable in the VE bus. I would assume this would supply all required information to the Cerbo. The MPPT is connected to the inverter via VE direct cable. Do i need to connect Cerbo to the inverter with a VE direct cable as well or am i missing a setting?
Multiplus-IIcerbo gx
