To use the Tank (or other relays in the MultiPlus-II GX, you shal go to "Relays" in the menu. I can't find relays in the menu..
The relay in the MultiPlus-II GX is a traditional MuliPlus (non GX) relay. Its programming otions are only available through VE.Configure.
This relay will not show up in the settings menu.
But this menu (Relay) is normally in stand alone Color Control GX for controlling of relay inside Color Control GX independently. It means GX functionality of Multiplus II GX in any case is not equivalent with CCGX + Multiplus . Relay inside "internal GX" of Multiplus II GX doesn't exist or is not lead to terminal for user. . This important feature is necessary to refer in data-sheet and manual of Multiplus II GX.
11 People are following this question.
