Hi
I have a EasySolar-II GX, can I use vbdup on the gx to update the firmware of the multiplus?
Hi
Hi, yes you can - but be aware that we don't use it - meaning that its not tested much, and settings are lost, and make sure that a reboot of the inverter/charger doesn't cause a shutdown of the GX Device and/or your access to it and so forth.
so all in all its unsupported.
Thanks, I am looking for a way to update the multi remotely, under lock down conditions.
Christo
13 People are following this question.
