hello,
is it possible to use a Phoenix Charger Control Panel with a MultiPlus (48/1600/20), and set with this panel the loading current of a battery-pack?
thanks, dirk
hello,
thanks, dirk
25 People are following this question.
Do I lose Bluetooth support if I use VE.Direct?
How to sequentially switch excess solar to water maker then hot water after batteries full
How can I realise a charge indication signal for the smaller MPPT-Charger models ?
I don't see the dot movement for the solar on my touch 50 like the DC side does
