beckwhoa avatar image
beckwhoa asked
Quattro Firmware Update
I’m trying to update the firmware of my Quattro 5000/12/110 system. Finding the correct firmware file is not clear. All online references point to a seven digit number. If I open my system, I see the following numbers:
2017051028hu
HQ1830W26RS
QUA12502110
HQ1830W26RS
Can someone please give me the correct firmware version? I’d like to know what each of the above numbers represent as well, if possible
I am performing the upgrade using ve.flash because my current firmware will not work via VictronConnect.
When I connect to my Quattro with VictronConnect, it says I’m running Firmware 413 and need to upgrade to 415 for it to function.
Thanks
MultiPlus Quattro Inverter Chargerfirmware update
The number you need is on the big CPU chip in the upper left on the PCB.
https://youtu.be/ZIn0mHLqU5Y?t=35
Yours should be 2733###
